The fit of rear cone into a hub?
AUSSIE
I've just been checking my rear hub after reading all the threads on here. Yes it's a ramp hub but its in perfect condition as far as I can see. My only issue is I need to know how far the rear hub cone is meant to fit into the hub taper? Mine seems to have around 5mm to go before it bottoms out, is this acceptable.
Thanks Dave
