60mm Crank for RB options
Bilko
Main scooter: LI150
I'm looking for a 60mm crank for the RB250.
Any recommendations up to the £250 mark?
Thanks
Bilko's Oily Blog
Train Driver
Can you get a quality crank for that money, i wouldn't want something cheap and cheerfull in my powerfull engine
J1MS
Harry Barlow has a hood reputation for building quality crankshafts. As does Jerome at reedspeeds. Also Taffspeeds. I woud think you might just get some change out of £250.
Dunno if this would be preferable to the RB crank .... but Mec 60mm race crank £100, Yamaha 110 Rod £25, Yamaha big end bearing £25, Ina small end bearing £8, 3mm packer £5, not sure what pin you'd need.
MB sell the rod and bearing as it's what they use in their Alpha cranks. Add in cost of pin, fitting and getting it balanced.
Bilko
Main scooter: LI150
Thanks for the replies everyone.
Food for thought, hopefully get the crank in a few weeks.
Bilko's Oily Blog
Let us know what you end up with.....
Bilko
Main scooter: LI150
Will do.
Bilko's Oily Blog
Lamaddict
So which 60mm crank did you get and how's the engine going?
Bilko
Main scooter: LI150
I forgot to post back 3 years ago!
I ended up getting This crank from PM Tuning. For the time I had the RB250 there was no issues with the crank. But due to non crank related issues, I moved on from the RB.
Bilko's Oily Blog
