26mm carb
scootcoot
Anyone know where i can get a 26mm dellorto carb from ?
am a doogal r u a doogal too....!
gaz_powell
assuming you mean the si type i`ve never seen one - mine came from sip years ago and i rang them to complain and they told me that they are all spaco
gaz_powell
to be honest i`ve fitted two (to different bikes) and they are both still going strong and have never gave any hassle......thats the kiss of death now!
but i personally dont think there is any improvement over a 24 with air box properly matched up
gaz_powell
sorry just realised this is the lambretta section........... just goes to show we can`t multi task!
Gary
goldeneye
gaz , ive seen you multi-task... walking, AND breathing! them reamed out 22/ 25/26 mm delly/jetex run ok if reamed properly, loads of lads have run them on budget tunes, and little hassle. 26mm phbh? why? just get a 30 or 28 which are easier to set up.
scootcoot
Not that easy unfortunately ! i need to replace one that i borrowed and dropped ! rendering it F****d !!! :oops:
