Li 125 Special - chain problem?
Posted: Thu Aug 20, 2009 7:33 pm
by Bon Viveur
Evening All,
recently bought a 1967 Li125 Special rebuild and from day one chain has been real noisy when not in gear - sounds like chain is rattling around . When engaged in gear the noise stops & sounds much happier.
Do i need a new chain or can it be altered easily by someone in-the-know?
B.V.
Re: Li 125 Special - chain problem?
Posted: Fri Aug 28, 2009 9:07 pm
by corrado
There's an adjuster inside the casing to take up excess play but if the adjuster is on the max adjustment and the chain's still slack then you'll probably need a new chain.
Posted: Sat Aug 29, 2009 10:39 am
by J1MS
Think you've got the right advice off corrado... and its only two 10mm bolts that need slackening then re-tightening...
If the rattle doesn't go when you have done this, then get someone to look at the clutch assembly and bearings... Its not a big job and usually only a couple of needle roller bearings need replacing, but sometimes a rattle that disappears when the clutch is engaged and the engine is put into gear has a little clutch wear on the assembly somewhere... with the right tools it would take no more than two hours to disassemble and reassemble if needed...
Posted: Sun Aug 30, 2009 12:48 am
by Bon Viveur
Thanks folks , much appreciated.
