Li 125 Special - chain problem?
Bon Viveur
Evening All,
recently bought a 1967 Li125 Special rebuild and from day one chain has been real noisy when not in gear - sounds like chain is rattling around . When engaged in gear the noise stops & sounds much happier.
Do i need a new chain or can it be altered easily by someone in-the-know?
B.V.
There's an adjuster inside the casing to take up excess play but if the adjuster is on the max adjustment and the chain's still slack then you'll probably need a new chain.
J1MS
Think you've got the right advice off corrado... and its only two 10mm bolts that need slackening then re-tightening...
If the rattle doesn't go when you have done this, then get someone to look at the clutch assembly and bearings... Its not a big job and usually only a couple of needle roller bearings need replacing, but sometimes a rattle that disappears when the clutch is engaged and the engine is put into gear has a little clutch wear on the assembly somewhere... with the right tools it would take no more than two hours to disassemble and reassemble if needed...
Bon Viveur
Thanks folks , much appreciated.
