Working Side Panel Grills
Bilko
Main scooter: LI150
I was thinking about cooling methods for the RB and remember last year on the way to a rally one of my side panels had come away a bit and my significant other was getting a warm leg.
Could the side panel grills be used as air intake vents or to let the hot air out?
Is there anyone who has made side panel grills that work as air vents or is it not worth while?
Bilko's Oily Blog
AUSSIE
are these the sort of thing you are thinking of?
http://cgi.ebay.co.uk/LAMBRETTA-GP-CUST ... .m14.l1262
cezeta
someone on the lcgb has done them. also its worth doing the same to the rear frame grill. most brit or german scooters have a air ext vent at this point. for some reason innocenti made theirs a dummy vent. cool air in is only worth while if the hot air can come out.
its one of the theories why serveta stopped using the flap on the pertol cap, the allow air to exit and the fuel stay cool? or beacause its pointless anyway?
Bilko
Main scooter: LI150
No, it was just the grills Aussie, although you've gave an idea with that.
Cezeta, I'll ask. Thanks.
I was considering doing a cut out at the rear grill, with maybe an adaption for better air flow exiting, but couldn't think of anything that wouldn't look stupid and didn't come up with anything. :/
Bilko's Oily Blog
cezeta
drill 8mm ish holes between the fins then file them out so they are grooves. then drill 25mm holes behind that. nice and discreat.
same as the side panels
Supereibar
Hmm.. Grilles on lammies go back to the Series 1. It was then when the grilles serve the purpose of air intake, but never for cooling. The only cooling device on a Lambretta that serves somewhat a purpose is the one in the flywheel, and even that has design flaws... I can't think of another machine with the cylinder in such an awkward position in respect to the coming air anyway. What a hell of a turn around it has to do to get to where it needs to go!
But why stop the nice warm feeling of hot air? Maybe now in summer it bothers you but in your winter weather.... Oh boy! I want all the warmth on earth for me!!!
RBG
I've done the same to both my gp panels on the RB. infact the holes are a little bigger.
I have found that with the RH panel cut like this, water hose mount for the carb and a diablo tank, I'm able to fit (with a little fettle to the elbow) an elbow with a Ramair filter to my 35mm Mikuni.
red
Try Chasspeed
http://www.chasspeedfabs.co.uk/index.htm
Don't know if he can make then to fit the grilles?
Worth a try though
Bilko
Main scooter: LI150
Thanks for the input everyone.
Mark, I didn't know it had been discussed before, thanks for the link. Food for thought.
Cheers for the link Red.
Bilko's Oily Blog
