long range tanks
scootcoot
I'm thinking of buying one of the stainless 13ltr fuel tanks ! ive a mugello setup with a ram filter !... If using the larger tank is there enough room for the sponge filter that sits on top of the rubber bellow to get enough air ? looking at it,it looks like it could get squashed between the panel and tank . (LI Special ) :|
am a doogal r u a doogal too....!
Maz
Yes, as long as you get a tank with a 'Cut out'
scootcoot
Thanks !!
red
And you seal it before you use it :D
doggbhoy
i fitted a long range tank with cut out for my muggy with ram air filter, found that it did not get enough air and had to turn the filter round so it sits kinda horizontalish above flywheel, ran sweet but wished i never had the cut out as it took up fuel space, the tank leaked anyway and i then got diablo to make me one of his superior tanks with the filter sitting this way,i have read on forums that you should not put the filter this way but that was eight months ago and a few rallies with no probs so far (touch wood) 8-)
