"Smokin"
carlos fandango
What would cause an engine to smoke excessively?
Pretty sure its not the oil seals or to much 2 stroke.
Could a cold plug cause it?
Supereibar
Lack of air. Have you checked your air intake? Your air filter system?
jackpot
could it be your crank,i've known it happen before if it's slightly out of true and rubbing on the seal it can release oil through the seal which in turn causes the exess smoke ?
ON MY SCOOT OR NOT AT ALL
red
Was that using one of those liquorice cranks :D
