Jet 200, 12v conv, GP crank, GP cylinder + SX 200 cyl head
cranky
Engine is completely standard.....
Aiming to change standard carb for a Mikuni TMX 24 + JL3 snail or AF 42mm reverse cone exhaust.
Can I use the standard 20mm manifold ? Can I run the carb 'open mouth' with panels ? Or would it be wise to utilise the standard air box ??
Any chance of 'ball park' jetting for the above ??
