Repairing an Italian 70mm barrel
Posted: Mon Jul 27, 2009 11:31 pm
by rog60
Can anyone advise on whether this barrel should be repaired/or is cost too high?
As you may be able to see one of the spigots has partly broken off!!!!
Re: Repairing an Italian 70mm barrel
Posted: Mon Jul 27, 2009 11:38 pm
by J1MS
Unless its somthing rare or exotic porting, I would say forget it... its going to cost around a £100 or more to put a spigot back on by fitting a steel liner...
Posted: Mon Jul 27, 2009 11:48 pm
by rog60
That's what I was thinking....................
I believe it to be an SX/TV barrel bored out to 70mmwith ports slightly enlarged and smoothed out.......
Posted: Mon Jul 27, 2009 11:50 pm
by davidblythe
have a TS barrell that has ran like that with no problems, chamfer it and the rest of the spigot will support the skirt,
but i am tight when it comes to spending money
if you run a jap piston you end up having to cut the spigot to match the cutaways
Posted: Mon Jul 27, 2009 11:52 pm
by rog60
It also has a crack that runs nearly the remainder of the spigot width.................
Posted: Mon Jul 27, 2009 11:55 pm
by rog60
Can you run a barrel without one or both spigots, I thought the piston used these at BDC. It is the lower spigot!!
Posted: Mon Jul 27, 2009 11:59 pm
by davidblythe
rog60 wrote:It also has a crack that runs nearly the remainder of the spigot width.................
thats a bit different
Posted: Tue Jul 28, 2009 12:02 am
by rog60
Posted: Tue Jul 28, 2009 12:04 am
by J1MS
The piston will try to tip into the inlet and/or exhaust a little more than normal as the skirt is not fully supported... wear would, I think, be rapid... It would no doubt run... But how long is anyones guess...
Posted: Tue Jul 28, 2009 12:10 am
by rog60
Guess it's for the recycle bin then..............?
