Repairing an Italian 70mm barrel
rog60
Main scooter: Indian GP200
Can anyone advise on whether this barrel should be repaired/or is cost too high?
As you may be able to see one of the spigots has partly broken off!!!!
J1MS
Unless its somthing rare or exotic porting, I would say forget it... its going to cost around a £100 or more to put a spigot back on by fitting a steel liner...
rog60
That's what I was thinking....................
I believe it to be an SX/TV barrel bored out to 70mmwith ports slightly enlarged and smoothed out.......
davidblythe
have a TS barrell that has ran like that with no problems, chamfer it and the rest of the spigot will support the skirt,
but i am tight when it comes to spending money
if you run a jap piston you end up having to cut the spigot to match the cutaways
rog60
It also has a crack that runs nearly the remainder of the spigot width.................
rog60
Can you run a barrel without one or both spigots, I thought the piston used these at BDC. It is the lower spigot!!
davidblythe
rog60 wrote:It also has a crack that runs nearly the remainder of the spigot width.................
thats a bit different
rog60
Yea, but you can't really see it........................ :lol: :lol: :lol: :lol: :lol: :lol:
J1MS
The piston will try to tip into the inlet and/or exhaust a little more than normal as the skirt is not fully supported... wear would, I think, be rapid... It would no doubt run... But how long is anyones guess...
rog60
Guess it's for the recycle bin then..............?
