Lambretta vape sport
Posted: Tue Sep 13, 2022 7:16 pm
by mickdale
Is there much involved in converting a lambretta vape sport to static?
Re: Lambretta vape sport
Posted: Tue Sep 13, 2022 7:21 pm
by Toddy
mickdale wrote: ↑Tue Sep 13, 2022 7:16 pm Is there much involved in converting a lambretta vape sport to static?
I believe it’s only swapping the cdi ?
Posted: Thu Sep 29, 2022 8:24 am
by jamjo
swap the cdi and change the timing to more suitable i used 17°
Posted: Fri Sep 30, 2022 9:30 am
by MilanoMod
Note that the Vape “static” does still have a curve, just much narrower. I used 19 degrees strobed at 4k rpm.
Posted: Thu Oct 06, 2022 4:39 pm
by Muppet
MilanoMod wrote: ↑Fri Sep 30, 2022 9:30 am Note that the Vape “static” does still have a curve, just much narrower. I used 19 degrees strobed at 4k rpm.
do wot he says pick a timing point and set it at 4000rpm; the timing point moves slightly advancing a degree or so at low revs then retards and becomes steady at and above 4000
