Lambretta vape sport
mickdale
Is there much involved in converting a lambretta vape sport to static?
mickdale wrote: ↑Tue Sep 13, 2022 7:16 pm Is there much involved in converting a lambretta vape sport to static?
I believe it’s only swapping the cdi ?
jamjo
Main scooter: gp 150/ 225
swap the cdi and change the timing to more suitable i used 17°
MilanoMod
Main scooter: ‘66 Lambretta SX200
Note that the Vape “static” does still have a curve, just much narrower. I used 19 degrees strobed at 4k rpm.
Muppet
MilanoMod wrote: ↑Fri Sep 30, 2022 9:30 am Note that the Vape “static” does still have a curve, just much narrower. I used 19 degrees strobed at 4k rpm.
do wot he says pick a timing point and set it at 4000rpm; the timing point moves slightly advancing a degree or so at low revs then retards and becomes steady at and above 4000
C’est la vie
