Engine storage
chippy
Need to build engine for dry build for frame mods. Could be up to 2 years before paint is finished. Will it be ok stored for this time or any advice as best thing to do. Thanks
Daggs
I stored a completely rebuilt engine for more than three years. When I came to use it apart from the clutch sticking initially, there were no problems.
Fruitjuice
I would suggest to seal inlet and exhaust (Stub if present) to the elements and spray some WD40 or 2 stroke oil in the bore with the piston at BDC
