Could it be the reeds
Just popped to the shops on my GT 186 came to a hill so gave it some then all power went pulled clutch in the bumped in 3rd then took it slow home then I tried to give it a bit more and did the same again thought it may be faulty stator but readings are fine with a volt meter and I tried new CDI plug etc and did the same. Now when I start it it will not rev and just stales if any load is given. Was getting dark do chucked in the shed. Would knacked reeds give this effect?
Norrie Bodge
- registered user
- Main scooter: GP-1971-Ts230/S2-1960-Ts230
- Contact:
LT coil
Cheers never thought the LT coil woundnt readings on volt meter be low if that was the fault?
Norrie Bodge
- registered user
- Contact:
Cheers will change it tommrow may as well do reeds while I'm at it been in a while
It's got a Reed valve which has fibre petals reeds these can split or even break meaning engine runs rubbish
Tractorman
- registered user
- Main scooter: Lambretta li150 special
- Contact:
Just got one in that would not run at all, one petal was completely missing.
