Could it be the reeds
boxofbits
Just popped to the shops on my GT 186 came to a hill so gave it some then all power went pulled clutch in the bumped in 3rd then took it slow home then I tried to give it a bit more and did the same again thought it may be faulty stator but readings are fine with a volt meter and I tried new CDI plug etc and did the same. Now when I start it it will not rev and just stales if any load is given. Was getting dark do chucked in the shed. Would knacked reeds give this effect?
Norrie Bodge
LT coil
boxofbits
Cheers never thought the LT coil woundnt readings on volt meter be low if that was the fault?
Norrie Bodge
boxofbits wrote: ↑Sat Feb 27, 2021 10:30 pm Cheers never thought the LT coil woundnt readings on volt meter be low if that was the fault?
Iv had good readings from a few stators with failing low tension coils m8
boxofbits
Cheers will change it tommrow may as well do reeds while I'm at it been in a while
MightyGem
Just out of curiosity, what are "reeds"?
boxofbits
It's got a Reed valve which has fibre petals reeds these can split or even break meaning engine runs rubbish
Tractorman
Just got one in that would not run at all, one petal was completely missing.
MightyGem
boxofbits wrote: ↑Sat Feb 27, 2021 11:06 pm It's got a Reed valve which has fibre petals reeds these can split or even break meaning engine runs rubbish
Thanks., and these are fitted where?
MightyGem wrote: ↑Sun Feb 28, 2021 10:21 pm
Under the inlet manifold Into the inlet of the cylinder widened to fit a Reed block in
