Lovely porting....
...not our work, but very nice....
fishi
through the barrel studs ???
can´t see any improvment of mixture flow going this way.
fishi
david
Playstation gamer tag: darkbretta
It's RS Performances Works, my TS1 with Xtra boost port! :D
David
RinB
fishi wrote:through the barrel studs ???
fishi
Are yes but what you can do is grind down you studs and make them thinner so gas can go round
Like this Now
Need I say any more :twisted:
Smiffy
fishi
fine art of work :shock:
but the RB will has them without grinding down the studs, with surly more mixture flow.
The engine cases on your photo, obviusly, is welded for an watercooled barrel with big transfers.
cheers
fishi
RinB
fishi wrote:fine art of work :shock:
cheers
fishi
Fishi you are quite right & I wont distprute it :)
But the above was done well before the concept of the RB m8
Smiffy
i presume that may be ralphs block...........
Avantone
RinB wrote:
Smiffy
Mmmmmmmmmmmmmmm ....................
Tony
www.lambrettagearbox.com
RinB
Sean ralph ????
Hey I like this Mod stuff :lol:
I think I showed a point :D
what happened to all those cool pictures? :cry:
    Users browsing this forum: Google [Bot] and 72 guests
