Are yes but what you can do is grind down you studs and make them thinner so gas can go roundfishi wrote:through the barrel studs ???
can´t see any improvment of mixture flow going this way.
fishi
Fishi you are quite right & I wont distprute itfishi wrote:fine art of work![]()
but the RB will has them without grinding down the studs, with surly more mixture flow.
The engine cases on your photo, obviusly, is welded for an watercooled barrel with big transfers.
cheers
fishi
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 4 guests
