Spaco dellorto SH2/22 carb
Lambretta67
Main scooter: Lambretta L.I. 200 special
Hi. Hope someone can help. Is the base setting for the mixture srew the same on the spaco dellorto SH2/22 carb . which was fitted on early Indian G.P. 200s the same as the dellorto carb fitted on the Italian G.P.
Exactly the same functionality but do note that the adjustment screw is exactly that, for adjustment. As such don't worry too much about what the book says, adjust to what the motor tells you what it wants in the way of turns. You may find it requires anywhere between 1/2 and 3 full turns out.
Lambretta67
Cheers Adam
