VMC 177
brynt
Main scooter: Vespa125TS
Hi,
I have a Px125 engine that I would like to get a little more performance from, has anyone any experience with the VMC 177 kit?
I am think of using it with a si24, polini box exhasut and a banded cosa clutch. Does that sound good?
cheers
Pete
gaz_powell
Didn't know anything about these kits but they look decent, one is entry level cast iron then an alloy/nicosil
I would expect similar performance to a polini or DR, without casing porting work.
I would nt worry about about banding the clutch ( what years is year bike, as it maybe cosa type already which will be adaquate.
I would use the standard carb upjetted before you try a 24mm.
Fit a fast flow tap and there are some simple float bowl alterations which will help.
I've not used the polini box pipe (only SIP R2 and now 3), I was toying with one as read good things but went SIP R3
It will give definaytely give you a bit more, you may need to change the gearing.
Good luck and keep us update
brynt
It's from 1987, it has the old 6 spring clutch, so worth replacing with a cosa clutch but no need for a banded basket. I'm happy to alter the standard carb and spend the money on a fastflow tap. I'm interested in what you think for gearing, I was thinking 22 clutch with the 68 primary?
Are you taking the whole thing to bits? It would benefit from matching it all up.
brynt
The engine is not in the scooter so I intend to do a complete rebuild.
tony172
Main scooter: vespa t5
22 clutch might be overkill, go 21
brynt
ok thank you
