34mm Polini Carb... Jetting?
Hi all,
Is anyone running a 34mm Polini carb on a piston port motor? If so, got a starting point for jetting please?
Once we're allowed back out onto the roads then I can start to evaluate any setup that I start with, however, knowing what others may be using would give me a place to start.
Thanks in advance.
Adam
The Polini is Keihin / PWK type carb.
Mrnice71
Main scooter: Lambretta series 3
Hooray some progress lol , one thing l wondered does the float needle valve come in different sizes or is it one fixed size ?
Mrnice71 wrote: ↑Mon May 04, 2020 9:55 pm Hooray some progress lol , one thing l wondered does the float needle valve come in different sizes or is it one fixed size ?
One size I think but pattern pwk's often need the jetway drilling out to prevent fuel starvation. There should be plenty of info on that on the web along with setting the float hieght
^... Yes, this was a very common issue with some copies but I hope that it will not come to light on this Polini version, time will tell.
