Page 1 of 2
Found a phbl sized foam filter for restricted room
Posted: Sun Aug 04, 2019 1:08 am
by Davidsquaredson
It's for a Briggs and Stratton lawn mower. I have no idea if you can get in the UK, I got it for 20$ on Amazon. Fits snug over the 39mm opening and perfectly under the panel. I did not have to adjust my jetting to my great surprise.
Part # on package.
DDImageImage
Sent from my Pixel 2 using Tapatalk
Re: Found a phbl sized foam filter for restricted room
Posted: Sun Aug 04, 2019 1:56 am
by paul d
Great post. Most towns here have someone who fixes lawnmowers. It could be a handy fix for anyone on the road who's lost an airfilter.
Posted: Sun Aug 04, 2019 6:37 pm
by gaz_powell
Pattern versions not genuine B&S £2.50 on ebay!!!
Posted: Sun Aug 04, 2019 6:42 pm
by gaz_powell
Found them for 99p! Worth a punt
Posted: Sun Aug 04, 2019 8:18 pm
by rosscla
Guessing it might be flexible enough to fit on a PHBH too if need be?
Posted: Tue Aug 06, 2019 1:56 pm
by gaz_powell
35mm dia hole in the filter
Posted: Sat Aug 10, 2019 2:05 pm
by YAMLAM
the cheap one i bought on ebay has a 40mm hole :(
Posted: Mon Aug 12, 2019 10:36 pm
by rosscla
That wouldn't be too much is a stretch on the phbh which is 42 mm without the plastic bellmouth
Posted: Sat Jan 04, 2020 1:11 am
by Warkton Tornado No.1
Any feedback on these filters from those that were going to get one to try?
Do they work well enough to be non restrictive?
Any issues with hot starting (due to flooding) from fans of the PH range?
Posted: Sat Jan 04, 2020 2:49 pm
by YAMLAM
Had to cut the corner away a bit on mine ,where the fuel bango /pipe is , i know the hole is slightly larger than my PHBL 25 but stays in place against the panel, doesnt affect the running at all.
be switching to a Mikuni TM24 soon , hopefully it will still fit .
