spaq disc brake
Posted: Mon Jun 24, 2019 9:57 pm
by TED CRUD
Anyone had any success setting one up tried different ways .bot the anti dive twist the backing plate causing the caliper to bind
Re: spaq disc brake
Posted: Mon Jun 24, 2019 10:58 pm
by rosscla
Picture might help.
I usually replace the tie bar with Rose joints and a bit of threaded bar
Re: spaq disc brake
Posted: Mon Jun 24, 2019 11:01 pm
by rosscla
Re: spaq disc brake
Posted: Tue Jun 25, 2019 6:11 am
by TED CRUD
I knew that there was a fix but I couldn't find anything. Do you know the sizes of the joints /bar and bolts
Re: spaq disc brake
Posted: Tue Jun 25, 2019 10:03 am
by wrecklessrobbie
That disc brake looks in a low position.
The tie bar looks long.
viewtopic.php?t=24975
The rose joints i bought are like these.
I have however removed by anti dive.
I did not enjoy it. So am just running a standard disc brake.
Robbie
Re: spaq disc brake
Posted: Tue Jun 25, 2019 6:03 pm
by gaz_powell
/\ same here, didnt like it from the off.
Put it to go Cleethorpes and removed as soon as i got back !
Re: spaq disc brake
Posted: Tue Jun 25, 2019 10:03 pm
by rosscla
The rose joints are M8 and the bar about 40 mm
The picture angle makes it look low - it's not as low as it looks
Re: spaq disc brake
Posted: Wed Jun 26, 2019 7:46 am
by TED CRUD
Thanks for the help lads, cheers
