Evening, I'm new to this forum lark and on my GP150 I have some headset rattling noise! I have changed the top and bottom fork bearings and there is no play or movement as far as I can see or feel and I have had the headset apart and again, no play, movement etc! I think I've got the locking nut not too tight but this noise is driving crackers! Any advice would be much appreciated
Dan
Headset rattling/noise
Dan Buchanan
- registered user
- Main scooter: GP150
- Contact:
Tractorman
- registered user
- Main scooter: Lambretta li150 special
- Contact:
If it rattles when you are stationary you could remove the handlebar top and you may find the problem. If removing the top cures it, it could be the little anti-rattle pads are worn or missing or despite the two screws being tight they do not tighten the top fully. It could be the horn touching the horn casting.
Dan Buchanan
- registered user
- Contact:
Afternoon Tractorman, thanks for a reply and that sounds interesting and funnily enough I got some anti vibration pads today as well as a few other bits! But where exactly would the pads go? I'm still new to all this Lambretta malarkey but your help is much appreciated
Lambretta67
- registered user
- Main scooter: Lambretta L.I. 200 special
- Contact:
I have a rattle in my headset & I have tried everything to stop it. Given up now & have learnt to live with it
