TS1 225 with Ron Moss ex box clubman phbh carb jetting
db67
Hi, just trying to sort my jetting for the above set-up & hopefully someone can point me in right direction jetting wise so I can get something like. current set-up is 30mm phbh dellorto with breath sweet filter 300 float valve jet, 145 main , 55 pilot, x13 needle 2nd clip from top & av 268 atomisor runs clean through the range with no 4 stroking. thanks for any info ;)
