Dell'orto PHBH 28 <-> 30 Slide?
Fruitjuice
Is the slide different between a Dell'orto PHBH 28 and a 30mm or can they be swapped over?
On a Mugello 198 with a Dell'Orto 28, what Slide would be most suitable when running a Clubman exhaust?
Muppet
slides are same on 30 & 28 you can swap
C’est la vie
number 40 slide is the most usual :)
YAMLAM
PHBH 26,28,30 all use the same jets, slide etc.
win or lose have a booze
