Phbh choke cable
tony172
Main scooter: vespa t5
What are guys doing for a choke cable on a phbh, fitted to a px? Mines just using a stranded normal inner bent over like the original wire was but that's a bit of a bodge. I've used the SIP choke knob with the grub screw before but I don't like it. Surely there's a correct way to do it?
mawso
Having the same problem, sometimes lever doesn't work, panel off and pull cable manually.
