Not strictly scooter related but Delloro VHSB 34QD carb help
ukoldschool
Hi all,
This isnt really scooter related (other than I think you could get a triumph Tina and a BSA scooter with a villers engine in...) but on my Historic kart I run a villers 9E with an upton alloy barrrel (5 port) bored out to make just under 210cc. It runs via an expansion exhaust and I run it using a Rotax Max 125 Dellorto 34 carb. The carb is standard other than running open, just the main jet has been changed to a 215, but it spits s**t loads of fuel out the back. Plug is a good colour and the thing really flies (Had great fun at Cadwell yesterday) but Ive alwasy wondered if I need to change atomisors/piloits etc to suit the larger capacity barrel than the 125 it was designed for....
I know a few people have stuck these carbs on modified lammies so thought id ask here
Cheers :)
ukoldschool
by the way, im not after anything hard and fast here, just interested in any similar set ups relating to this type of carb. 225 lammie, 210 vespa etc
cheers!
Diablo
From memory Ts1s run about a 175 main jet
