polini 210 help
p2nm
Main scooter: p2
Hi all
just purchased the latest polini 210 kit,is any body else running one that coud give me help with timing,jetting etc
to start i will running standard 24/24 carb with sip road exhaust.
any help appreciatted
You still running standard jetting?
p2nm
Main scooter: p2
hi
was looking to up the main jet to around the 128 mark,was interested in what others were running that plus timings
cheers
Set timing to 18 (IT mark) check what pilot, atomiser, air corrector and main are.
I
p2nm
Main scooter: p2
cheers mate
jets in the carb at present are 55/160 pilot /be3 atomiser/air corrector 160 was looking for advice on main as polini say 120 -125 which i thought would be on the lean side from what others have said,will the head bolts torque setting be the same as the cast iron kit?
thanks
eibargum
What carb settings did you end up with.
