Hi all
just purchased the latest polini 210 kit,is any body else running one that coud give me help with timing,jetting etc
to start i will running standard 24/24 carb with sip road exhaust.
any help appreciatted
polini 210 help
- drunkmunkey6969
- Moderator
- Contact:
You still running standard jetting?
hi
was looking to up the main jet to around the 128 mark,was interested in what others were running that plus timings
cheers
cheers
- drunkmunkey6969
- Moderator
- Contact:
Set timing to 18 (IT mark) check what pilot, atomiser, air corrector and main are.
I
I
cheers mate
jets in the carb at present are 55/160 pilot /be3 atomiser/air corrector 160 was looking for advice on main as polini say 120 -125 which i thought would be on the lean side from what others have said,will the head bolts torque setting be the same as the cast iron kit?
thanks
thanks
