Quatrini 210 exhaust potions
Grumpy225
I see Chisel speed sells a couple of exhausts for the 210 but I haven't been able to get one from them yet.
Is there any other options? The kit looks like a RB exhaust should fit but I haven't seen that confirmed anywhere.
hendy
Mick Abbey will be able to sort you out.
i believe the RB pipe will fit but needs the Holes elongating on the Flange as the port is flattened on one side
Grumpy225
Toddy wrote: ↑Thu Oct 25, 2018 6:09 am i believe the RB pipe will fit but needs the Holes elongating on the Flange as the port is flattened on one side
That should be easy enough to check, I think I have an extra stub kicking around.
hendy wrote: ↑Wed Oct 24, 2018 9:21 pm Mick Abbey will be able to sort you out.
Thanks for the point. I'll have my customer reach out to him about it.
vegansydney
Also Cosmoto and I believe Pipe Design have one in the works. Here are some dyno comparisons of various pipes (might need to log in view).
Grumpy225
vegansydney wrote: ↑Fri Oct 26, 2018 7:08 pm Also Cosmoto and I believe Pipe Design have one in the works. Here are some dyno comparisons of various pipes (might need to log in view).
I have a Pipe Design exhaust on my RB. Very nice work. I had heard there were some issues getting pipes from him but that was a few years ago. Hopefully everything is sorted out now.
