piston ring end gap
mick094m
Anyone help with the end gap for a GP200, oversize piston 67.6
chris2470
I like to use 0.10mm per inch of bore.
Thus 2.66 inches x the above is 0.26mm or 11 thou.
Hope this helps
Best Regards
Chris
156 D
..........ring gap should be between 7 to 12 thou......depending how you want to treat it straight afterwards???.....
RinB
This is what I use
Std type kits upto ST4
Bore........ Gap thou of Inch
70mm..............11..
66mm..............10..
Tuned/race type kits
70mm..............13..
66mm..............12..
mick094m
thanks for the help
