SSC Cassette Clutch
Lamaddict
I’ve got one of the latest SSC cassette clutches. I’ve used the other set of ‘race’ springs that it comes with. I have tightened everything down and have notice the plates are lose, is this normal?
I tightened down the 4 bolts compressing the springs totally down, if that was the right thing to do?
Lamaddict
Still stuck on this, even some fitting instructions would be useful. I’m doing something wrong ☹️
GTFOMWSC
Main scooter: GP230 Super Monza CS Tuned
Try Jerome at Readspeed he might be able to help think he knows a bit about them or give you advice.
the man don't give a f@@k
dapper
Would have thought that if you've tightened the springs right down, then they cannot put pressure on the corks /steels to bind against each other ??
