Weird Problem
Posted: Sun Jul 22, 2018 8:18 pm
by fsmlittler
So my scooter was starting first kick and running fine but now it won’t start unless I give it a few squirts of carb cleaner. Once it’s running it is absolutely fine.
The set up is RT200 with a PHBH30 and JL pipe.
I’ve stripped and sonic cleaned the carb twice but it’s made no difference. I run without a filter and all of this has run fine for ages.
Re: Weird Problem
Posted: Sun Jul 22, 2018 8:41 pm
by coaster
Have you done the obvious like fitting a new plu?g
Re: Weird Problem
Posted: Sun Jul 22, 2018 9:24 pm
by mick1
Stuck rings ?
Air leak ?
Re: Weird Problem
Posted: Tue Jul 24, 2018 8:24 am
by fsmlittler
I assumed it was fuelling in some way since it starts with a squirt of carb cleaner and once running is fine
Re: Weird Problem
Posted: Wed Aug 01, 2018 12:44 pm
by EddieStone
Check the choke mech is definitely working properly.
How many miles has it done? Check the compression, sounds like worn rings/bore.
