Weird Problem
fsmlittler
So my scooter was starting first kick and running fine but now it won’t start unless I give it a few squirts of carb cleaner. Once it’s running it is absolutely fine.
The set up is RT200 with a PHBH30 and JL pipe.
I’ve stripped and sonic cleaned the carb twice but it’s made no difference. I run without a filter and all of this has run fine for ages.
Have you done the obvious like fitting a new plu?g
mick1
Main scooter: Li Avanti 225
Stuck rings ?
Air leak ?
fsmlittler
I assumed it was fuelling in some way since it starts with a squirt of carb cleaner and once running is fine
EddieStone
Check the choke mech is definitely working properly.
How many miles has it done? Check the compression, sounds like worn rings/bore.
    Users browsing this forum: Google [Bot] and 30 guests
