Emergency Repair Kit for the Road
railfancwb
Or if you prefer you may call it a “Get Me Back Home Kit”...
What should be in such a kit for the P200e, for example?
I have seen cable insides mentioned -
Two gear shift cables
One clutch cable
One throttle cable
One front brake cable
One back brake cable
Light bulbs -
Headlight
Tail/Brake light
Turn signal lights
Spark plug
Anything else?
I have not seen the cable end clamps (by whatever name) mentioned, but seems a few in each size would make sense.
2 x spark plugs as you never know if the first spare is a dud.
Cable nipples - yes
Spare wheel nuts and washers.
Spare inner tube.
Duck tape and some tie wraps / zip ties.
A few crimp on electrical connectors and insulating tape.
WD40 to spray round the CDI if you live in a wet climate.
Spare CDI for when you run out of WD40.
Spare oil drain / filler plug screws.
