Reed valve crank clearance
hungdog
Does it matter what the clearance is on reed cranks against the housing outside edge of crank ? ie thin edges.
If i had the housing enlarged to 100mm diameter and then used a standard reed crank would it work ?
hungdog
anyone ?
Grumpy225
"the housing outside edge of crank" More info would be helpful here.
What's a "standard reed crank"? Is that like a stock hot rod?
If I had to render a guess, is this for a vespa?
Not trying to be difficult here but the details are important if you want actual relevant help.
