Disc brake locating stud, fine thread - where to buy?
Posted: Fri Apr 13, 2018 7:52 am
by fluff34567
Hi all,
I'm after the locating stud for the original Italian disc brake. I bought 2 studs from different suppliers but both don't fit.
The stud is not the same thread as the main spindle.
Confirmed supplier recommendations welcome.
Thanks!
Sent from my BND-L21 using Tapatalk
Re: Disc brake locating stud, fine thread - where to buy?
Posted: Fri Apr 13, 2018 9:36 pm
by rosscla
Posted: Sat Apr 14, 2018 8:53 am
by HxPaul
Maybe the thread in the disc brake has been tapped out.Why did you change it and where is the original stud?
Posted: Sat Apr 14, 2018 10:03 am
by HxPaul
Are you sure its original.The after market inboard disc brake had a coarser thread in the backplate.http://scootrs.com/category.cfm?category=84
Posted: Sat Apr 14, 2018 12:25 pm
by storkfoot
As an aside, every toolkit should include a Pitch Gauge. Cheap and a very easy way to find out what pitch you are dealing with.
Posted: Sat Apr 14, 2018 12:42 pm
by hendy
storkfoot wrote: ↑Sat Apr 14, 2018 12:25 pm As an aside, every toolkit should include a Pitch Gauge. Cheap and a very easy way to find out what pitch you are dealing with.
You're dead right. I always p155 about counting threads and measuring with verniers. It's a reet clart.
But I read this and I've just ordered a gauge. The rest of my life will be better now. Thanks.
Posted: Sat Apr 14, 2018 1:16 pm
by fluff34567
That's one of the places I ordered from, doesn't fit sadly.
HxPaul wrote:Maybe the thread in the disc brake has been tapped out.Why did you change it and where is the original stud?
All in a box of bits so no knowledge of previous parts. Thread hasn't been changed.
HxPaul wrote:Are you sure its original.The after market inboard disc brake had a coarser thread in the backplate.http://scootrs.com/category.cfm?category=84
Has all the correct markings so can only assume it's original. Appears to be a finer thread rather than coarser.
I thought scooters went out of business?
Are series 2 and series 3 backplates exactly the same? It's a very very early series 3 and has the late s2 early s3 forks with the welded cable loop, wondering if its a mash up.
