Disc brake locating stud, fine thread - where to buy?
fluff34567
Hi all,
I'm after the locating stud for the original Italian disc brake. I bought 2 studs from different suppliers but both don't fit.
The stud is not the same thread as the main spindle.
Confirmed supplier recommendations welcome.
Thanks!
Sent from my BND-L21 using Tapatalk
HxPaul
Maybe the thread in the disc brake has been tapped out.Why did you change it and where is the original stud?
HxPaul
Are you sure its original.The after market inboard disc brake had a coarser thread in the backplate.http://scootrs.com/category.cfm?category=84
storkfoot
As an aside, every toolkit should include a Pitch Gauge. Cheap and a very easy way to find out what pitch you are dealing with.
hendy
storkfoot wrote: ↑Sat Apr 14, 2018 12:25 pm As an aside, every toolkit should include a Pitch Gauge. Cheap and a very easy way to find out what pitch you are dealing with.
You're dead right. I always p155 about counting threads and measuring with verniers. It's a reet clart.
But I read this and I've just ordered a gauge. The rest of my life will be better now. Thanks.
fluff34567
That's one of the places I ordered from, doesn't fit sadly.
HxPaul wrote:Maybe the thread in the disc brake has been tapped out.Why did you change it and where is the original stud?
All in a box of bits so no knowledge of previous parts. Thread hasn't been changed.
HxPaul wrote:Are you sure its original.The after market inboard disc brake had a coarser thread in the backplate.http://scootrs.com/category.cfm?category=84
Has all the correct markings so can only assume it's original. Appears to be a finer thread rather than coarser.
I thought scooters went out of business?
Are series 2 and series 3 backplates exactly the same? It's a very very early series 3 and has the late s2 early s3 forks with the welded cable loop, wondering if its a mash up.
