Scootering went over to Butcher Garage in St. Petersburg to meet up with the lads. It’s a powerhouse of invention and attention to detail, as well as being a brilliant place with characters to match. This superb Vespa Scrambler is a collab between Butcher and SIP, and suffice to say…it’s an awesome piece of engineering, using top quality components, executed in a stunning paint finish.
The full story is available in our new ‘Scootering Extra’ Subs Club – There you can login and see the full story, read all about the engineering and components, and view the huge selection of hi-res, detailed shots. Subscribers go directly to www.scootering.com/extra
Photographs by: Roman Sokolov, Mitya Ganopolsky Studio, and Rik
Engine spec.
-Crankcase PINASCO ‘Slave’ version - Powered by Butcher Garage
-Racing Cylinder PARMAKIT TSV 177
-Flowed Racing Crankshaft SERIE PRO by Worb5
-Carburetor KEIHIN PWK 35mm
-Reed Valve Block TASSINARI V-force 4
-Racing Air Filter RAMAIR
-Ignition MALOSSI VesPower MKII
-Input Shaft DRT for SIP SPITFIRE ROAD 12-13-17-20
-Driveshaft PIAGGIO/DRT "PX Lusso" 57-42-38-35
-Primary Driven Gear DRT 68 teeth
-Clutch SIP ‘COSA 2’ Sport 22
-Pressure Plate Clutch SIP
-Clutch Cover PIAGGIO by MMW
-Selector Box ‘PX Lusso’
-Engine Mounting Bush Plc Corse
-Racing Exhaust SIP Performance
