Lambretta Speedo Light Always On
Posted: Mon Mar 26, 2018 8:17 pm
by Northener
I've an Italian GP150 totally standard 6v AC (non-battery), when i kick this up & it is only on ignition (first right turn) the speedo light is on, it wasn't before but is now, can only assume some wires maybe touching after working on it.
Anyone who's more electrically minded got any ideas?
Thanks.
Re: Lambretta Speedo Light Always On
Posted: Mon Mar 26, 2018 8:28 pm
by rosscla
Welcome aboard.
Sounds like your black speedo bulb wire is connected directly to the wire bringing power up you your headset junction box - probably a brown but maybe purple.
The speedo light should be connected to the black from the switch and the one that goes to the tail lamp.
Posted: Fri Mar 30, 2018 3:35 pm
by Northener
It was what you said 'rosscla' so thanks for your help everything sorted now!
Posted: Wed Apr 18, 2018 9:16 am
by rosscla
Good work
Posted: Tue May 29, 2018 9:03 am
by drunkmunkey6969
welcome to the forum, glad you are getting stuck in and getting good advice straight off the bat!
