Speedo Bulb
Posted: Fri Mar 09, 2018 11:23 am
by Blenks
Bought a replacement speedo bulb holder for my Li150 S3 and it has not got an earth lead. The one I am replacing did have. Had a look on the net and most that are being sold only have the one connection. Is it necessary to earth the speedo bulb?
Re: Speedo Bulb
Posted: Fri Mar 09, 2018 12:08 pm
by HxPaul
Either solder an earth wire on the side of the bulb holder,as in pics.Or do as I do.Strip the insulation off the earth wire and trap it when you slide the bulb and holder in place.https://www.google.co.uk/search?q=pictu ... Q8a-ELKXtM:
PS.It needs and earth wire on the series 3 speedo because the housing is plastic.
Re: Speedo Bulb
Posted: Fri Mar 09, 2018 12:28 pm
by Blenks
Thanks paul. I think I will just use the original, it has two spades, one for power and one for earth. I only replaced it as all other wiring is new.
Re: Speedo Bulb
Posted: Sat Mar 10, 2018 4:32 pm
by Monty
Look out if its one of the nasty ones with a metal block and a screw gripping the wire they are too long and short out on the headstock clamp, I snap them off and solder a wire through the hole left add another to the outside for earth. Pain in the bum but better than a direct short to ground
