Speedo Bulb
Blenks
Main scooter: Lambretta S3 Li150
Bought a replacement speedo bulb holder for my Li150 S3 and it has not got an earth lead. The one I am replacing did have. Had a look on the net and most that are being sold only have the one connection. Is it necessary to earth the speedo bulb?
HxPaul
Either solder an earth wire on the side of the bulb holder,as in pics.Or do as I do.Strip the insulation off the earth wire and trap it when you slide the bulb and holder in place.https://www.google.co.uk/search?q=pictu ... Q8a-ELKXtM:
PS.It needs and earth wire on the series 3 speedo because the housing is plastic.
Blenks
Thanks paul. I think I will just use the original, it has two spades, one for power and one for earth. I only replaced it as all other wiring is new.
Monty
Look out if its one of the nasty ones with a metal block and a screw gripping the wire they are too long and short out on the headstock clamp, I snap them off and solder a wire through the hole left add another to the outside for earth. Pain in the bum but better than a direct short to ground
