AC 12V Wiring Diagram
Posted: Mon Feb 26, 2018 9:35 am
Got the point in the restoration I was dreading, the connecting up of the wiring. Managed to make sense of the drawing I received with the MB simple wiring loom to connect up the rectifier and CDI unit. It is the headlight junction box and horn that is throwing me. There is a red wire breakout from the main loom at the horn. There is also a breakout from the switch wiring to the horn which has a brown wire and a white wire. I know these can be connected to the horn either way around. But, there are three connections and only two connection points on the horn. Any ideas? Do I splice the red loom wire with one of the switch wires? If so, which one?
Does anyone know where I can find a good diagram of the connections for the headlight junction box.
For info I have a MB developments 12V AC simplified wiring loom (no accessories) and a CASA light / horn switch
I HATE ANYTHING ELECTRICAL!!!!!!!!!
