AC 12V Wiring Diagram
Blenks
Main scooter: Lambretta S3 Li150
Got the point in the restoration I was dreading, the connecting up of the wiring. Managed to make sense of the drawing I received with the MB simple wiring loom to connect up the rectifier and CDI unit. It is the headlight junction box and horn that is throwing me. There is a red wire breakout from the main loom at the horn. There is also a breakout from the switch wiring to the horn which has a brown wire and a white wire. I know these can be connected to the horn either way around. But, there are three connections and only two connection points on the horn. Any ideas? Do I splice the red loom wire with one of the switch wires? If so, which one?
Does anyone know where I can find a good diagram of the connections for the headlight junction box.
For info I have a MB developments 12V AC simplified wiring loom (no accessories) and a CASA light / horn switch
I HATE ANYTHING ELECTRICAL!!!!!!!!!
garry inglis
Brown and white to horn place the red with the Brown in the headset
Blenks
Thanks for the quick reply Garry. No problem to fit the brown and white to the horn. However, the red from the loom is a breakout next to the horn and is well short of the headset.
garry inglis
The red is for dc horn and will be spare on a.c. as mb looms are multi fit
garry inglis
garry inglis wrote:The red is for dc horn and will be spare on a.c. as mb looms are multi fit
Just had a look and the red is coming from stoplight so splice it in with the Brown as in picture Image
Blenks
Brilliant. Thanks a lot Garry.
    Users browsing this forum: Baidu [Spider], Google [Bot] and 7 guests
