Pinasco Split Rims and SIP Calliper
GFlint
Main scooter: Vespa PX200
Hi All,
Read that the Pinasco split rims foul the PM calliper. Just wondered if the SIP calliper is OK or suffers the same? Anyone running them both on a PX with any problems?
Thanks
Gary
If you don't tinker, you won't learn anything, but you won't break anything either :)
GFlint
No one running Pinasco rims and SIP calliper?
GFlint
SIP replied and said they couldn’t answer this as their tech team have never tested this combination
I can't remember where my Pinasco rims came from now, but whoever it was, hadn't even tested them on regular length studs.
They didn't fit.
GFlint
PINASCO REPLIED
Hi, We checked the fitting of SIP calliper, you're right, it doesn't fit on our rims without some modification which WE DO NOT RECOMMEND TO DO IT.
Some have said the Mk1 version fits, so msybe this is just the newer rims. Standard Grimica callipers don't appdar to have a problem.
Just in case anyone is interested
G
    Users browsing this forum: No registered users and 54 guests
