Stator lifting plates?
Hi all,
Can someone please remind me where I’ve seen the spacer/lifting ring for stators, which allow you to lift the stator for pickup alignment, without having to disturb the pickup itself? I thought that I might have seen these on a SULK thread but cannot now find it. Yes, I am fully aware of the small plates that can be added under the pickup itself, however, those do not serve my requirement/want for quick swaps of stators and flywheels (instant testing of multiple components with less buggering about). Perhaps I am totally wrong about the SULK connection but pointing me in the right direction would be very much appreciated.
Ta
Adam
HxPaul
Doesn't Anthony Tambs do the stator lifting rings,I know he does the small plates that go in between the pick up and the laminates.
I'll drop Anthony a line to check. Thanks
HxPaul
These are the only stator spacer plates I have found,but there for a Vespa http://www.scooter-center.com/en/produc ... 20mm?meta=
I too found those whilst looking, however, these are specific to Lambretta stators and cut to match the profile of the stator's base plate, including the 3 adjustment slots.
Well done (and thanks) as Anthony Tambs is the guy producing and supplying these.
Ta
Muppet
cut up any old stators ya have then thers plenty of lifting plates
C’est la vie
