SS250 - keep centre plug or not?
Posted: Tue Feb 13, 2018 9:41 pm
by alanscottj
Just finished SS250 build - it came with a centre plug rather than the usual offset. I am considering swapping it for the offset - will there be much difference power/reliability wise of doing the swap? I'm assuming that they use the centre plug for a reason? It's a pain in the backside as I have to remove the rear shock in order to get to the plug :roll: Not accessible at all for plug chops and not practical at all for gaining access at the side of the road.
Any thoughts guys?
Many thanks!
Re: SS250 - keep centre plug or not?
Posted: Wed Feb 14, 2018 4:33 pm
by GTFOMWSC
If you do decide to change it i'd be interested in your centre plug head cowl as i'm just building an RB225 with a centre plug head and need one.
Posted: Tue Feb 20, 2018 8:46 am
by Fux
I have a standard non centerd head on my SS250 but I havn`t run it yet.
Can`t see why it would be a problem. I actually don`t think I could use a centerd plug with my exhaust because I had to grind down my head cowl fixing bolt to fit the pipe already.
Posted: Tue Feb 20, 2018 10:31 pm
by alanscottj
Fux wrote: ↑Tue Feb 20, 2018 8:46 am I have a standard non centerd head on my SS250 but I havn`t run it yet.
Spoke to Dean the other day and he recommends keeping the centre plug - it's easily accessible if I drop the shock which isn't a major job ;)
Posted: Wed Feb 21, 2018 8:46 am
by Fux
He also doesn`t reccomend TMX 35 carbs.
Can you remember your jetting?
Posted: Wed Feb 21, 2018 9:48 pm
by alanscottj
Fux wrote: ↑Wed Feb 21, 2018 8:46 am He also doesn`t reccomend TMX 35 carbs.
I'm using 34mm VHSB not the TMX
Posted: Wed Feb 21, 2018 9:49 pm
by Fux
Ahh.. ok sir.
