SS250 - keep centre plug or not?
alanscottj
Just finished SS250 build - it came with a centre plug rather than the usual offset. I am considering swapping it for the offset - will there be much difference power/reliability wise of doing the swap? I'm assuming that they use the centre plug for a reason? It's a pain in the backside as I have to remove the rear shock in order to get to the plug :roll: Not accessible at all for plug chops and not practical at all for gaining access at the side of the road.
Any thoughts guys?
Many thanks!
GTFOMWSC
Main scooter: GP230 Super Monza CS Tuned
If you do decide to change it i'd be interested in your centre plug head cowl as i'm just building an RB225 with a centre plug head and need one.
the man don't give a f@@k
Fux
Main scooter: li150 S2
I have a standard non centerd head on my SS250 but I havn`t run it yet.
Can`t see why it would be a problem. I actually don`t think I could use a centerd plug with my exhaust because I had to grind down my head cowl fixing bolt to fit the pipe already.
alanscottj
Fux wrote: โ†‘Tue Feb 20, 2018 8:46 am I have a standard non centerd head on my SS250 but I havn`t run it yet.
Spoke to Dean the other day and he recommends keeping the centre plug - it's easily accessible if I drop the shock which isn't a major job ;)
Fux
He also doesn`t reccomend TMX 35 carbs.
Can you remember your jetting?
alanscottj
Fux wrote: โ†‘Wed Feb 21, 2018 8:46 am He also doesn`t reccomend TMX 35 carbs.
I'm using 34mm VHSB not the TMX
Fux
Ahh.. ok sir.
