Side Panel Badges drilling template?
loadedscooterist
Main scooter: lambretta li150 special
Hi All,
Has anyone out there got a template for drilling so I can put the emblems back onto the side panels on a S3 panel without screwing it up? or failing that what have others when you have had to do this in the past? :?:
Cheers in advance
B
garry inglis
Put a strip of 2" masking tape along the area put felt tip on the pins on the badge and press on the tape and drill measure the first hole a nd transfer onto the other side and press on again from the first hole
hendy
What he said or alternatively use plasticine.
Tractorman
Or bluetack.
loadedscooterist
Thanks for the replies guys. I will give that a go!!! :D
